Warning message
IPCC Express Scripting
Dec 6th, 2005
Looking for the Cisco IPCC Express Script repository. Needing to know how to have the queue check for estimated hold time and based on a certain amount of time continue to next step in script.
bullett Tue, 12/06/2005 - 16:15
C:/program files/wfavvid is the path for scripts on the server. The repository is used when the scripts are uploaded and running and is in whatever path you defined in Active Directory.
Chris Deren Tue, 12/06/2005 - 18:42
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
I think this is what you are looking for:
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/products_implementation_design_guides_list.html
to check for extimated hold time you can use "Get reporting statistics" step where you can check "Expected Wait Time" for a particular CSQ. You would store it as a variable and then create a genarated prompt to play it back.
I have attached a sample script.
Rate the post if it helps!
Chris
lmrscheff Wed, 12/07/2005 - 06:53
I was looking for the sample scripts I thought Cisco had a library of sample scripts that you could refer to. Does anyone know about this??
Chris Deren Wed, 12/07/2005 - 08:24
  • Hall of Fame,
It's in the link I posted, the last link on the page takes you to a zip file that has a lot of them.
Chris
Telematic Thu, 03/29/2007 - 03:51
Hi Chris,
I need your ExpectedWaitTime.aef script for make some test but that you posted in the past was expired. Pls can you attach again?
thx
Franco
