Warning message
MDS 9216 with no OS on it, need help
Dec 7th, 2005
We just received a 9216 as a replacement for our existing 9216 having trouble and it does not have any SANOS image on it, boots in monitor mode. any documentation would be highly appreciated, also how can i access the gui one i have loaded the OS and give it a management address?
I will surely rate this post.
Overall Rating: 5 (1 ratings)
tblancha Wed, 12/07/2005 - 09:38
  • Cisco Employee,
Following is an older sample config on how to recover the SAN-OS. Once it it up & running, all you have to do is point your web browser to the IP address of the mgmt interface and then select Fabric manager and it will install. The FM/DM package is available from the download section of the Cisco website as well.
1.) At the loader prompt, add ip address and default gateway. And then get a kickstart image into memory
Loader>ip address 172.18.172.57 255.255.255.0
Loader> ip default-gateway 172.18.172.1
Loader> boot tftp://172.18.172.79/m9500-sf1ek9-kickstart-mzg.1.2.0.96.bin
2.) It will boot up to a (boot) prompt. So now get a regular image onto bootflash and boot it.
Switch(boot)# config t
Switch(boot)(config)# interface mgmt 0
Switch(boot)(config-mgmt0)# ip address 172.18.172.57 255.255.255.0
Switch(boot)(config-mgmt0)# no shut
Switch(boot)(config-mgmt0)# exit
Switch(boot)(config)# ip default-gateway 172.18.172.1
Switch(boot)(config)# exit
Switch(boot)# copy tftp:m9500-sf1ek9-mzg.1.2.0.96.bin bootflash:m9500-sf1ek9-mzg.1.2.0.96.bin
Switch(boot)# load bootflash:m9500-sf1ek9-mzg.1.2.0.96.bin
3.) The switch should come up in normal mode and you will be able to login. But you need to set the boot variables at this time. First get the kickstart image onto bootflash.
Switch# copy tftp://172.18.172.79/m9500-sf1ek9-kickstart-mzg.1.2.0.96.bin bootflash:///m9500-sf1ek9-kickstart-mzg.1.2.0.96.bin
Switch# config t
Switch(config)# boot kickstart bootflash: m9500-sf1ek9-kickstart-mzg.1.2.0.96.bin
Switch(config)# exit
Switch# copy running-config startup-config
Trending Topics: Storage Networking
