Warning message
Getting CME 3.2 to send # and *
Dec 9th, 2005
Our Telecom supplier has a service which was used with the previous phone system and naturally we want the same service to be available with CME ( We have 4xFXO lines but one main number ).
The user would dial the following in order to forward all calls made to the main number to an external number. E.g.:
1) *21*077712345678# all calls would be sent to 077712345678
And to switch this service off:
2) #21#
I can get the router to send 1) but not 2) I want to be able to send the # to the Telecom switch and for it not to be interpreted as an "end of digits" signal to the GW.
Is there a way of changing this default action?
Here is the translation-rule I have been playing with:
1111 - is the PIN number that has to be sent with the request - but this should be transparent to the user.
voice translation-rule 4
rule 5 /^\(\*21\)\(1111\)\(\*\)\(.*\)\(\#\)/ /\1\2\3\4\5/
rule 6 /^\(\*21\)\(\*\)\(.*\)/ /\1111\2\3/
rule 7 /^\(\#21\)\(\#\)/ /\11111\2/
rule 8 /^\(\#211111\)\(\#\)/ /\1\2/
voice translation-profile BT_Service
translate called 4
dial-peer voice 1 pots
translation-profile outgoing BT_Service
destination-pattern *21T
no digit-strip
port 0/0/3
dial-peer voice 2 pots
destination-pattern #21T
no digit-strip
port 0/0/3
