Warning message
ISDN Dead
Dec 9th, 2005
Over the last few days, ISDN connection would disconnect with just a few seconds of inactivity even though disconnect is set at 300 seconds. Often, clear int bri0 was required to reconnect. Follosing is part of message with the clear command:
PANIC! Dumping old buffered faults.
PANIC! Dumping fault causing the panic.
Memory Protection Violation:
epc =0x001AB388, location of fault eva =Ox00000???, write fault address
error=0x00000080, illegal address pti 0x00000000 pte =OXFFFFF100
== Flushing messages (05:50:16 central Thu Dec 8 2005)
Queued messages: 23:08:50: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
23:08:214748364800: %SYS-3-MGDTIMER: NZ prey pointer but not running, timer = 6B 4210.
-Process= “ISDN”, ipl= 6, pid= 42
-Traceback= 1AA874 1AB3D8 1AB560 4BA86C 4D1B94 4D38A0 4AF8B4 4AF884
Data TLB Error Exception (0x1400)! CPU Register Context: VEC = 0x00001400 PC = 0x0O1AB388 MSR = 0x00009032 CR = 0x33000030
Finally, the bri interface has died. Following are the last few lines of a log:
LINK-3-UPDOWN: Interface BRI0:2, changed state to down
2005-12-09 01:45:00 Local7.Error 192.168.0.1 92: 04:03:188985410468: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
2005-12-09 01:45:11 Local7.Error 192.168.0.1 93: 04:03:236224735096: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
2005-12-09 01:45:23 Local7.Error 192.168.0.1 94: 04:04:34366587812: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
2005-12-09 01:50:45 Local7.Error 192.168.0.1 95: 04:09:128855868244: %LINK-3-UPDOWN: Interface BRI0:2, changed state to up
2005-12-09 01:53:33 Local7.Error 192.168.0.1 96: 04:12:77310945144: %LINK-3-UPDOWN: Interface BRI0:2, changed state to down
2005-12-09 01:54:00 Local7.Error 192.168.0.1 97: 04:12:188980094840: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
2005-12-09 02:05:37 Local7.Error 192.168.0.1 98: 04:24:21: %SYS-3-MGDTIMER: NZ prev pointer but not running, timer = 6B4210.
2005-12-09 02:05:37 Local7.Error 192.168.0.1 99: -Process= "ISDN L2 Process", ipl= 6, pid= 52
2005-12-09 02:05:37 Local7.Error 192.168.0.1 100: -Traceback= 1AA874 1AAC94 1AF3D0 4BB1E0 3203C
And finally, console messages as the interface died today:
518BD8 handle 0
00:08:28: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 66 changed to uponfiguration:
00:08:30: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 67 changed to down
00:08:39: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 67 changed to up
00:08:39: event = 0x1403
00:08:39: %ISDN-6-NO_TIMER: No Free Timer Entry, caller 0x5185A0, timers used 41
00:08:39: %ISDN-6-INVALID_TIMER: LIF_StartTimer: Invalid Timer Handle, caller 0x518BD8 handle 0
00:08:40: %ISDN-6-LAYER2UP: Layer 2 for Interface BR0, TEI 68 changed to up
00:08:40: event = 0x1403
00:08:40: %ISDN-6-NO_TIMER: No Free Timer Entry, caller 0x5185A0, timers used 41
00:08:40: %ISDN-6-INVALID_TIMER: LIF_StartTimer: Invalid Timer Handle, caller 0x518BD8 handle 0
00:09:55834615808: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI0, TEI 67 changed to down
00:09:13: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 67 changed to down
00:09:55834615808: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BRI0, TEI 68 changed to down
00:09:13: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 68 changed to down
00:09:13: %SYS-3-MGDTIMER: NZ prev pointer but not running, timer = 6B4210.
-Process= "ISDN L2 Process", ipl= 6, pid= 53
I know that I need to run some debugs but I'm on the road, so thought someone may save me some time by at least pointing me to the more likely direct problem.
Telco switches were checked and everything is ok on their end.
Richard Burts Fri, 12/09/2005 - 10:31
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Given these messages:
It looks to me like there is a serious software issue (perhaps provoked by a hardware issue). I would suggest that you open a TAC case on this one.
As an interim step, is a reload of the router an option for this box?
Rick
supmedidata Wed, 12/22/2010 - 06:06
CSCsl17539 Bug Details
Bus error crash in mgd_timer_set_exptime_internal
Symptoms: A Cisco router may reload with the following symptoms:
Oct 31 22:55:21.282: %SYS-3-MGDTIMER: NZ prev pointer but not running, timer = 64C37818. -
Process= "IP Input", ipl= 4, pid= 66 -Traceback= 0x60746048 0x6084EA34 0x6084F14C 0x62333AD8
0x62337C70 0x62306494 0x623068B0 0x60A40654 0x60A416F8 0x60A41778 0x60A41964 Oct 31
22:55:48.894: %SYS-3-MGDTIMER: Setting zero expiration time, timer = 64132350. -Process= "IPSEC
key engine", ipl= 4, pid= 150 -Traceback= 0x60746048 0x6084E9A8 0x6084FA18
22:55:48 zulu Wed Oct 31 2007: Address Error (load or instruction fetch) exception, CPU signal 10, PC =
0x60815B08
0x60815B08 0x6084FCA4 0x622B2E54 0x622B39C4
Conditions: Occurred on a Cisco 7206VXR running Cisco IOS Release 12.4(16).
Workaround: There is no workaround.
paolo bevilacqua Wed, 12/22/2010 - 06:11
  • Hall of Fame,
    Founding Member
Original post, 2005.
Answered in 2010.
By 2015 it should be rated ?
