Warning message
SRST-->WAN-->UNITY/CCM
thisisshanky Fri, 12/09/2005 - 13:11
  • Purple, 4500 points or more
This is not something you want to happen, under non-srst mode - correct ? So if you use connection plar, you will always route calls to the AA in Unity. (Unless you manually remove the command out of there).
Under SRST mode, how would you dial the outbound call to Unity ? Is it again going out through the PSTN using a 10 digit prefix (11 digit for londdistance) to dial Unity pilot number via the PSTN ?
If then you can put a default-destination command under call-manager-fallback mode and have it route to a 10 digit number which is the pilot number of Unity AA.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide_chapter09186a008018131b.html#wp1350685
PS: Please remember to rate replies!
