Voice-port (of the third E1 interface) goes in Administratively shutdown af
Dec 12th, 2005
The Voice-port (of the third E1 interface) goes in Administratively shutdown after reset/reboot of CallManager 4.1(3)sr2.
voice-port 0/1/0:15
shutdown
cptone NL
This is on a Cisco 2811 gateway fitted with a VWIC-2MFT-E1 in port 0 and a VWIC-1MFT-E1 in port 1 using MGCP.
After a "no shutdown" (and write) everything works okay, until CallManager reboots or even when a "reset gateway" is issued.
Any idea why this happens?
Here's the config:
NLAVLV01#sh run
Building configuration...
Current configuration : 3325 bytes
! Last configuration change at 20:21:48 MET Fri Dec 9 2005 by xxx
! NVRAM config last updated at 20:21:49 MET Fri Dec 9 2005 by xxx
version 12.3
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
hostname NLAVLV01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
clock timezone MET 1
clock summer-time MEZT recurring last Sun Mar 3:00 last Sun Oct 2:00
network-clock-participate wic 0
network-clock-participate wic 1
no network-clock-participate aim 0
no network-clock-participate aim 1
network-clock-select 2 E1 0/0/0
network-clock-select 3 E1 0/1/0
network-clock-select 4 E1 0/0/1
no aaa new-model
ip subnet-zero
ip cef
ip domain name nlav.voip
ip host NLAVLC01 a.a.a.a
ip host NLAVLC02 b.b.b.b
no ftp-server write-enable
isdn switch-type primary-net5
voice-card 0
no dspfarm
ccm-manager switchback immediate
ccm-manager fallback-mgcp
ccm-manager redundant-host NLAVLC02
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server NLAVLC01
ccm-manager config
controller E1 0/0/0
clock source line primary
pri-group timeslots 1-31 service mgcp
description ISDN30 to Colt 1
controller E1 0/0/1
description ISDN30 to Vodafone
controller E1 0/1/0
description ISDN30 to Colt 2
interface FastEthernet0/0
description LAN Interface to Network
ip address y.y.y.y 255.255.255.0
duplex full
speed 100
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0:15
no ip address
isdn incoming-voice voice
isdn bind-l3 ccm-manager
no cdp enable
interface Serial0/0/1:15
no ip address
no cdp enable
interface Serial0/1/0:15
no ip address
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
control-plane
voice-port 0/1/0:15
cptone NL
voice-port 0/0/0:15
cptone NL
voice-port 0/0/1:15
cptone NL
mgcp
mgcp call-agent NLAVLC01 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp modem passthrough voip codec g711alaw
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp rtp payload-type g726r16 static
mgcp profile default
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
subhrojyoti.banerjee Mon, 12/12/2005 - 05:59
hi,
i think i had one case quite similar to your one. can you get me the following information-
sh ccm-man
Show mgcp endpoint db
sh ver
after getting the above information can you get the debug out of the following debugs when you do a RESET of REBOOT of CCM. Please make sure you turn on the debugs before you do the reboot or reset.
debug mgcp events
debug mgcp packet
debug mgcp errors
subhrojyoti
