Unity upgrade, adding a failover server and hardware migration
imad.dandis
Looking into upgrading unity’s ver 4.03 unified messaging with no failover to 4.05 and migrating the server from 7835 to 7845 as well as adding a failover server.
I know that I need to upgrade the current server to the 4.05 and back up its database then build the new server with 4.05 then restore the backup.
I need to know if there is any gotchas in doing this upgrade/migration
Imad
Hin Lee
I would backup the 4.0(3) before you upgrade to 4.0(5), and make sure both 403 & 405 backups are good. You are going to need a lot of time to do this and more so if you have many subscribers.
The message store is exchange 2000 and the OS is windows 2000. Do I need to re run the permission wizard on the new server.
Yes, you will need to assign permissions for the existing domain accounts for the new server's local groups.
