srst-timers
Dec 13th, 2005
I am looking for the commands for two timers.
1) keepalive to callmanager so SRST kicks in quicker
2) when in srst mode -it takes 10 secs for a call to establish- (is this interdigit time out?)
Overall Rating: 5 (1 ratings)
thisisshanky Tue, 12/13/2005 - 07:27
  • Purple, 4500 points or more
1. Go to Callmanager - Service - Service Parameters. Choose the CM and Cisco Callmanager service. Change the parameter "Station Keepalive Interval". Default is 30 s, you can change it to as low as 10. Just a side note, that reducing KA can cause lot more traffic on the network (more frequently)
2. I think your dial-peers are matching T pattern which waits 10 secs after the last digit you dial, before sending the digits to PSTN. YOu can change it using timeout interdigits command under call-manager-fallback mode.
http://www.cisco.com/en/US/products/sw/voicesw/ps2169/products_command_reference_chapter09186a0080551c6e.html#wp1141696
PS: Please remember to rate helpful replies!
