Warning message
Can I place outbound calls using a VIC-4FXS/DID card?
Dec 14th, 2005
I have a 2821 with a VIC-4FXS/DID card...can I use this card for outbound calling if I have it setup for DID. I want to receive DID calls and place outbound calls on this card.
Running IOS 12.3(14)T5.
Thanks!
m-geisler Fri, 02/27/2015 - 11:18
Hi lkrol,
seems you are out of luck!
" Serves only incoming calls from the PSTN"
Quote from:
http://www.cisco.com/c/en/us/products/collateral/routers/2600-series-mul...
So it also seems to be a software limitation:
http://www.cisco.com/c/en/us/support/docs/voice/analog-signaling-e-m-did...
Let me know if a newer version or better router changes anything.
On the other hand PRI/BRI don't seem to have this limitation!
Mike
