EIGRP default route injection
Dec 14th, 2005
Hi All,
Any one knows how to inject default routes in EIGRP to a particular EIGRP neighbor. Lets say we have router A,B and C. I want to inject an EIGRP default route from A to B and not to C.I know its possible in OSPF.
Praful
ankurbhasin Wed, 12/14/2005 - 17:41
  • Red, 2250 points or more
Hi Praful,
There are two ways to inject a default route into EIGRP: redistribute a static route or summarize to 0.0.0.0/0.
Summarizing to a default route is effective only when you want to provide remote sites with a default route. Since summaries are configured per interface, you do not need to worry about using distribute-lists or other mechanisms to prevent the default route from being propagated toward the 3rd router.
Check this link for more details and some good points regarding EIGRP
http://www.cisco.com/warp/customer/103/eigrp-toc.html#defaultrouting
Ankur
