Lan to Lan (Pix-VPN3000) Fails at IKE QM
Dec 14th, 2005
Hi all,
I am really having problems when trying to stablish a site to site vpn between a PIX 6.3(5) and a VPN 3000.
IKE Phase 1 finishs Ok but when begining IKE Phase 2 QM it sudenly fails without begining to negotiate the IPSECs SAs, please check logs below:
ISAKMP (0): SA has been authenticated
ISAKMP (0): beginning Quick Mode exchange, M-ID of -1233180032:b67f2a80IPSEC(key_engine): got a queue event...
IPSEC(spi_response): getting spi 0xc83f0a84(3359574660) for SA
from 193.149.246.8 to 217.130.212.207 for prot 3
return status is IKMP_NO_ERROR
ISAKMP (0): sending INITIAL_CONTACT notify
ISAKMP (0): sending NOTIFY message 24578 protocol 1
VPN Peer: ISAKMP: Added new peer: ip:193.149.246.8/500 Total VPN Peers:1
VPN Peer: ISAKMP: Peer ip:193.149.246.8/500 Ref cnt incremented to:1 Total VPN Peers:1
crypto_isakmp_process_block:src:193.149.246.8, dest:217.130.212.207 spt:500 dpt:500
ISAKMP (0): processing DELETE payload. message ID = 3949233630, spi size = 16
ISAKMP (0): deleting SA: src 217.130.212.207, dst 193.149.246.8
return status is IKMP_NO_ERR_NO_TRANS
ISADB: reaper checking SA 0x1024c24, conn_id = 0 DELETE IT!
The relevant configuration for the PIX is posted below, just notify that it is working also as a VPN Remote Server.
At all the tests, the traffic was originated at the pix side, destinated to the VPN side.
crypto ipsec transform-set nuevo esp-3des esp-md5-hmac
crypto ipsec transform-set nuevo2 esp-3des esp-sha-hmac
crypto dynamic-map pick_dynmap 11 set transform-set pick_ts
crypto map rpick 10 ipsec-isakmp dynamic pick_dynmap
crypto map rpick client authentication LOCAL
crypto map VPN 10 ipsec-isakmp
crypto map VPN 10 match address VPN3
crypto map VPN 10 set peer 193.149.246.8
crypto map VPN 10 set transform-set nuevo
crypto map VPN 20 ipsec-isakmp dynamic pick_dynmap
crypto map VPN client authentication LOCAL
crypto map VPN interface outside
isakmp enable outside
isakmp key ******** address 193.149.246.8 netmask 255.255.255.255 no-xauth
isakmp peer ip 193.149.246.8 no-xauth
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup default-domain idle-time 1800
vpngroup ppack address-pool poolPick
vpngroup ppack split-tunnel splitPick3
vpngroup ppack idle-time 1800
vpngroup ppack password ********
Any tip for fixing this or about what is failing?
Thanks a lot in advance.
Sam.
IP Addresses have been altered to save the innocencts.
a-vazquez Tue, 12/20/2005 - 14:05
  • Silver, 250 points or more
This document gives an overview of the configuration required to allow a Cisco Secure PIX Firewall and a Cisco VPN 500x Concentrator to open an IPSec LAN-to-LAN tunnel. For information about how to establish basic connectivity, or for reference on configuration syntax, consult the VPN 5000 Concentrator documentation and the PIX documentation.
http://www.cisco.com/warp/public/110/pixto5000.html
