Warning message
Prioritizing sites for dial backup
Dec 16th, 2005
Is there a way to prioritize one site over another when using dialer watch? What would be ideal is if a site with a "higher priority" could have the ability to force a disconnect of a "lower priority" site that was already using the dial backup lines. The scenario is a 7200 with a PRI at the central site that provides dial backup using dialer watch for several remote sites in a hub and spoke environment. The central site initiates all dial backup connections already and I'm trying to figure out if theres a way to drop a call in progress from the "lower priority" site if a "higher priority" site requires the PRI but no channels are available at the time.
