xlate
jackko Sun, 12/18/2005 - 20:35
  • Gold, 750 points or more
also check out the command "sh conn", which provides more info on the actuall data flow.
naveed-khan Wed, 12/28/2005 - 04:28
if you want to do more testing then you can do one thing.
clear the xlate entery only for your required server ip address.
after pushing this command your connection of server should be break.
show connection is also a better way to check your connectivity.
