Warning message
difference between pix 7.0 and asa 7.0
Dec 17th, 2005
couls anyone pls clarify the differnce between asa 7.0 and pix 7.0 ios . i checked with the command reference . bo the ioses have the same commands. i guess the only difference between the two is that the asa can have a inbuilt antivirus and ips engine making it a single box solution . whereas with pix u need to have a external ips. any more differnces pls share. thank u
sushil
pradeepde Thu, 12/22/2005 - 11:46
  • Bronze, 100 points or more
On the PIX security appliance, the failover link can be either a LAN-based connection or a dedicated serial Failover cable. But on the ASA platform, the failover link can only be a LAN-based connection
sachinraja Thu, 12/22/2005 - 20:32
  • Red, 2250 points or more
Sushil,
Most of the features are common between these two devices.. One of the most important difference I can see is that PIX V7.0 does not support WebVPN, whereas ASA supports....
Just check for the release notes for more information.
Hope this helps... all the best...
Raj
