Warning message
strange performance of ASA 5510
10 days ago I installed ASA 5510 at a site. I was using image 7.0 (2). Static translations on a DMZ interface didn't work (I know PIX OS very well so this is not due to misconfiguration ) while dynamic translations worked. I upgraded to 7.0(4) and faced some very strange problems:
- Most of the time the command sh run hangs the ssh session, so I have to open another one.
- Sometimes write memory doesn't work, warning that 'configuration is in progress', while nobody is configuring it.
- The strangest of all is that sometimes the internal subnet is being messed up and computers are not able to communicate with each other. The LAN has no problems, as another firewall works without any problems. Re-placing the old firewall (it's not from Cisco) solves all the above mentioned problems.
Has anyone any experience with this equipment. What I'm not sure whether these are due to software bugs or some hardware malfunction.
I'll apprecieate any help
pradeepde Fri, 12/23/2005 - 07:43
  • Bronze, 100 points or more
Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/cgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered
