Warning message
RISDC.EXE - Unable To Locate DLL Error
Answered Question
Dec 19th, 2005
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
On a new installation of CCM 4.1(3)SR1 I noticed the following information popup:
Application popup: RISDC.EXE - Unable To Locate DLL : The dynamic link library INETCOMM.dll could not be found in the specified path C:\WINNT\System32;.;C:\WINNT\system32;C:\WINNT\system;C:\WINNT;C:\WINNT\system32;C:\WINNT;C:\WINNT\System32\Wbem;C:\Program Files\Microsoft SQL Server\80\Tools\BINN;C:\dcdsrvr\bin;C:\dcdsrvr\lib;C:\PROGRA~1\DATACO~1\DCDIRE~1\bin;C:\Program Files\Cisco\bin;C:\Program Files\Cisco\MA;C:\Program Files\Cisco\EM\Bin;C:\CiscoWebs\art\Web-Inf\lib.
I am not sure what this causes, has anyone expereiced this?
Chris
Correct Answer by agopala about 11 years 8 months ago
If the problem persists after a reboot, you are hitting CSCeg88885..
Unless you are using RTMT, you will not have any issues.
You should download win-K9-ReinstallIE6sp1.exe
from http://www.cisco.com/cgi-bin/tablebuild.pl/cmva-3des and install it. That should fix the problem.
Overall Rating: 5 (1 ratings)
Chris Deren Mon, 12/19/2005 - 16:26
  • Hall of Fame,
Reboot seemed to have fixed the issue. Thanks.
Chris
Erick Bergquist Tue, 03/21/2006 - 22:26
  • Silver, 250 points or more
So will reinstalling the IE6 fix this error for RISDC or is not recommended? I am having this also and a reboot cleared but my RIS DC was getting this error then the service was terminating so looking for a fix so it doesn't happen again. Before it terminated, CCMAdmin started responding very slow and device status's showed incorrectly.
The bug toolkit for the bug above does not really say much. It is marked resolved and workaround saids unknown.
agopala Wed, 03/22/2006 - 07:43
  • Cisco Employee,
yeah, please do install that fix. It will not have any negative effects on your system.
