4.1(3) Pickup fails with HuntPilot\LineGroup
Dec 20th, 2005
  • Bronze, 100 points or more
From 7912-A dial the Hunt Pilot which contans member 7912-B, then on 7912-C
press Pickup you get a on-hook/offhook.
If I dial the directory number of 7912-B, then on 7912-C press pickup it works fine.
Is there a by-design limitation of Call Pickup with Line Groups? Perhaps bug CSCsb42763?
Same pickup group, calling search space, partition, etc. No shared lines.
Overall Rating: 5 (1 ratings)
b.speltz Mon, 12/26/2005 - 11:23
By design, Call pickup does not work with Line groups. You can make use the workaround suggested in CSCsb42763.
marinaibm Wed, 12/28/2005 - 04:46
  • Silver, 250 points or more
You would need 4.1(3)sr1 or sr2 to enable it
1. Enter CSCsb42763 (in mixed case) in the Enterprise Parameter 'Cisco Support Use 1'
under the new group 'Cisco Support use Only' and click update. Only the value CSCsb42763 in this parameter can enable the configuration in step 2.
(note:Change the value to anything else to disable this functionality.)
2. Go to Hunt Pilot Configuration page and select a call pickup group from the Call Pickup Group dropdown list and click update.
rala Fri, 01/13/2006 - 00:56
After configuring this callpickup in hunt group is working.
But after this Call Forwad Internal and External does not functioning anymore as it should.
woodj1979 Wed, 02/08/2006 - 14:41
I am unable to find the 'Cisco Support Use 1" in my Enterprise Parameters. Is there something else I need to do to be able to find this? I'm using 4.1(3)sr1
James
Aaron Harrison Wed, 03/01/2006 - 02:41
  • Community Spotlight Award,
    Member's Choice, May 2015
Good find...
Aaron
jcp408 Wed, 04/05/2006 - 20:22
Please verify funcitonality. Is the call pickup group assigned to the hunt pilot only applicable to calls "in process" in the hunt list and any call pickup groups already asssigned in DN line confiugration of the phones are still only for direct calls to those lines?
Jon
