vip & interface redundancy for css11506
Answered Question
Dec 20th, 2005
When I configure redundancy on my two css11506s, I find when I put acl on, I can not see the vip if not working fine.
and also, if remove redundancy it works fine.
my access list is only bypass ssh and permit VIPs. do I need add more for redundancy?
Any comments will be appreciated
Thanks in advance
Correct Answer by Gilles Dufour about 11 years 8 months ago
if you create acl, you need to permit the vrrp traffic [dst ip == 224.0.0.18].
Gilles.
Thanks for rating this answer.
Overall Rating: 5 (2 ratings)
Correct Answer
Gilles Dufour Wed, 12/21/2005 - 00:18
  • Cisco Employee,
Gilles.
julxu Wed, 12/21/2005 - 16:08
what is the source ip ? I did:
master:
circuit VLAN295
ip address 10.2.95.2 255.255.255.0
ip virtual-router 2 110 preempt
ip redundant-interface 2 10.2.95.1
ip critical-service 2 upstream-downstream
backup:
circuit VLAN295
ip address 10.2.95.3 255.255.255.0
ip virtual-router 2
so the acl should be:
clause 1 permit ip 10.2.95.2 destination 224.0.0.18?
Should I use bypass?
Should I use src ip as any?
Please advance.
julxu Wed, 12/21/2005 - 17:44
I think I found the solution myself. the src should be the interfaces of vrrp.
I will try today and thanks for help.
Gilles Dufour Thu, 12/22/2005 - 01:06
  • Cisco Employee,
the source is the ip address configured on the interface where you configured the virtual vip or virtual interface.
So in your example, your clause 1 is correct.
Gilles.
