Warning message
troubleshooting return traffic with 1841+vpn client
On 15-Dec-2005 I posted a message entitled "some return traffic not going through vpn tunnel (although not all)". Either the post was overwhelming or considered not worthy of a reply so I will attempt to simplify it in the hopes of getting some feedback.
Basically I am trying to determine why port 25 TCP traffic flows correctly (through the VPN tunnel) from the VPN software client to the SMTP server behind an 1841. However, return traffic from the server to the client does not flow back through the VPN tunnel (it routes back out through the public IP address). Traffic on other ports seems to flow properly back and forth in the tunnel.
It seems like the SMTP server does not know how to route the traffic back through the tunnel to the VPN client so it sends the packets out the default gateway. There are no static routes other than the entry for default outbound traffic:
ip route 0.0.0.0 0.0.0.0 Dialer0
Port mapping and other NAT entries are as follows:
ip nat inside source list 110 interface dialer0 overload
ip nat inside source static tcp 10.0.0.209 25 interface dialer0 25 ! exchange smtp virtual server
ip nat inside source static tcp 10.0.0.209 80 interface dialer0 80 ! exchange owa access
ip nat inside source static tcp 10.0.0.209 443 interface dialer0 443 ! exchange owa access - ssl
ip nat inside source route-map SDM_RMAP_1 interface Dialer0 overload ! crypto
The ACL 110 is the following:
access-list 110 deny ip 10.0.0.0 0.0.0.255 10.10.10.0 0.0.0.255 ! no nat for vpn
access-list 110 permit ip 10.0.0.0 0.0.0.255 any
access-list 110 permit ip 10.10.10.0 0.0.0.255 any
The route map looks like this:
route-map SDM_RMAP_1 permit 1
match ip address 110
The interface FastEthernet0/0 is configured like this:
ip address 10.0.0.250 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
no ip redirects
no ip unreachables
no ip proxy-arp
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
no cdp enable
no mop enabled
hold-queue 32 in
hold-queue 100 out
And the interface Dialer0 is like this:
ip address negotiated
ip mtu 1492
ip nat outside
ip inspect my-out-rules out
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ****@****.***
ppp chap password *****
ppp pap sent-username ****@****.*** password *****
crypto map SDM_CMAP_1
Can anyone offer suggestions for troubleshooting this apparent routing problem? Thanks! -Louie
jackko Wed, 12/21/2005 - 15:11
  • Gold, 750 points or more
interesting.
the server should have no idea about the public ip, as the packet has been decrypted by the router before forwarding to the server.
in other words, from the server point of view, the packet is originated from one of the vpn client pool i.e. 10.10.10.x.
