12-21-2005 07:41 AM
Just a short question:
Does the 5510 Security Plus ASA support totally 15 interfaces (5 x phy. and 10 x virtually) or just totally 10?
thanks for the feedback
Oliver
Solved! Go to Solution.
12-21-2005 10:54 PM
Oliver,
It can support 10 additional VLAN interfaces with the existing 5 physical interfaces. One of the physical interface will be used as a trunk for VLAN configuration... You can max use 15 interfaces, though i would normally think of using 14 max (as 1 interface goes for trunk)
Hope this helps... rate replies if found useful
Raj
12-21-2005 10:54 PM
Oliver,
Raj
