Warning message
Cat6500 conversion from hybrid to native
Answered Question
Dec 21st, 2005
Is there a tool that will covert your existing supervisor configuration to a native IOS configuration?
Correct Answer by thisisshanky about 11 years 8 months ago
Please be aware that not all configs will convert properly with this tool You might want to understand equivalent commands under each OS before you do the migration.
Check this link.
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010e9d5.shtml
PS: please remember to rate helpful replies!
Correct Answer by Georg Pauwen about 11 years 8 months ago
Hello Jeff,
are you looking for this ?
Catalyst OS to Cisco IOS Configuration Converter
http://www.cisco.com/cgi-bin/Support/CatCfgConversion/catcfg_xlat.pl
GP
Overall Rating: 5 (3 ratings)
apmorgan Mon, 01/09/2006 - 07:12
This tool does not seem to be working at least over the last 5 days.
I have tried to upload and convert 8.3 catos config, and also tried cutting and pasting in the conversion box.
Browser status says: Opening page http://...catcfg_xlat.pl..
But conversion never happens, browser just times out.
Anyone else having problems?
mbernhardt Mon, 01/09/2006 - 09:20
Yes, I had the same problem. I finally wrote a perl script to do the port-level configuration because I had a ton of ports. Adjust as you see fit:
open (PORTS,"sw2.txt");
open (NEWSW1,">sw2-new.txt");
@ports = ;
foreach (@ports) {
($port,$desc,$conn,$vlan) = /(\d+\/\d+)\s+(.*)\s+(connected|notconnect)\s+(\d+)\s+/;
if ($conn) {
print NEWSW1
"interface g$port\n desc $desc\n switchport host\n switchport access vlan $vlan\n no shutdown\n";
Correct Answer
thisisshanky Wed, 12/21/2005 - 13:04
  • Purple, 4500 points or more
Check this link.
