routing
Dec 22nd, 2005
If I have 2 sites. 1 router on the remote site has say an ip address of 10.1.1.1/24 and the serial is ip unnumbered, and the main site has a router with its Wan ip on the same subnet, would the router on the main site need a route on it pointing to the remote site, even though its wan port is on the same network ?
vpalania Thu, 12/22/2005 - 04:25
If the subnet and mask are same, then it should as directly connected.
HTH,
Vijay
carl_townshend Thu, 12/22/2005 - 07:01
Would this be an ok or right way to do it ?, and so from the main site to the remote site, I dont need any routes ?
spremkumar Thu, 12/22/2005 - 07:18
  • Red, 2250 points or more
Hi Carl
The better/general recomm would be using a /30 ip for the WAN conenctivity and make use of seperate /24 in ur local lans on both the sides.
I feel tht would be easier for troubleshooting and for operational purpose..
if u really dont have any choice in moving to the best practice then better to stay out with the current scenario..
regds
mheusinger Thu, 12/22/2005 - 07:32
  • Green, 3000 points or more
Well I do not think it would work.
Assuming this topology:
(e0)R1(s0) - (s0)R2(e0)
with
R1: e0 10.1.1.254/24 and s0 ip unnumbered e0
R2: s0 10.1.1.1/24
How would R1 find the way to R2 without additional static route pointing to R2? It would not.
So the better choice is f.e.
R1 e0 10.1.1.1/24 and s0 10.1.2.1/30
R2 e0 10.1.3.1/24 and s0 10.1.2.2/30
plus either static or dynamic routing on R1 and R2.
Hope this helps
Martin
carl_townshend Thu, 12/22/2005 - 08:08
if I did use dynamic routing would I need to advertise both addresses on each router ?
spremkumar Thu, 12/22/2005 - 23:49
You need to advertise the networks/address(interfaces) which u require to be advertised to the peers or to be included in the routing process.
regds
