Can not ping the SIP registrar
Dec 22nd, 2005
Please can anybody tell me what I did wrong on the config attached I cannot receive SIP invite or ping the sip registrar. Tell me how to fix the issue. Thx.
------------------ show running-config ------------------
Building configuration...
Current configuration : 2092 bytes
version 12.4
hostname 3640
boot-start-marker
boot-end-marker
enable secret 5
enable password
no aaa new-model
resource policy
clock timezone gmt 5
voice-card 1
ip subnet-zero
ip cef
isdn switch-type primary-5ess
voice service voip
redirect ip2ip
sip
no call service stop
controller T1 1/0
framing esf
clock source internal
linecode b8zs
cablelength short 133
pri-group timeslots 1-24
controller T1 1/1
framing esf
linecode b8zs
interface FastEthernet0/0
ip address 72.24.19.13 255.0.0.248
speed auto
full-duplex
no mop enabled
interface Serial1/0:23
no ip address
isdn protocol-emulate network
isdn incoming-voice voice
no cdp enable
interface Serial1/1:23
no ip address
no cdp enable
interface Ethernet2/0
no ip address
shutdown
half-duplex
interface Ethernet2/1
no ip address
shutdown
half-duplex
ip http server
ip classless
snmp-server community RO
control-plane
voice-port 1/0:23
voice-port 1/1:23
sccp ip precedence 1
dial-peer voice 1 pots
service session
destination-pattern ..........T
port 1/0:23
dial-peer voice 2 voip
service session
destination-pattern .T
redirect ip2ip
session protocol sipv2
session target ipv4:72.24.19.14
session transport udp
dial-peer voice 4 pots
service session
port 1/1:23
dial-peer voice 5 voip
service session
redirect ip2ip
session target ipv4:72.24.19.12
sip-ua
retry register 10
registrar ipv4:72.24.19.14 expires 3600 tcp
sip-server ipv4:72.24.19.12
gatekeeper
shutdown
line con 0
line aux 0
line vty 0 4
password
login
end
Please note those IP addresses are wrong.
