Warning message
Route Filter, Route Pattern Question
Dec 23rd, 2005
We have a route pattern 9.@ with a route filter of Local Office Codes:
END-OF-DIALING DOES-NOT-EXIST AND OFFICE-CODE == 554) OR
(END-OF-DIALING DOES-NOT-EXIST AND OFFICE-CODE == 444) OR
(OFFICE-CODE == 443 AND END-OF-DIALING DOES-NOT-EXIST) OR
(OFFICE-CODE == 898 AND END-OF-DIALING DOES-NOT-EXIST)
If a user dials 94438981 there is a interdigit timeout...I understnd this is because Call manager picks up the 898 as a office code and it waiting for 3 more digits...even if I change the Route Filter to Area Code does not exist I still get the interdigit timeout...is there a way to resolve this issue...
Joe Harbison
Overall Rating: 5 (1 ratings)
gogasca Fri, 12/23/2005 - 07:35
  • Green, 3000 points or more
Hi Joe,
You need to add LOCAL AREA CODE does not exit to that filter.
joeharb Fri, 12/23/2005 - 07:53
That appeared to have worked....Does the Local Area code not exist tell it that it is only 7 digit dialing? I had added that the area code does not exist but not the Local Area code...
Thanks for your help...
gogasca Fri, 12/23/2005 - 15:41
That is correct when you use that option you are restricting to dial 7-digit Local calls
YYY - XXX - XXXX , YYY is the Local Area Code
1 ZZZ - XXX - XXXX ZZZ is the Area Code
