Nm-CIDS-K9 needed IOS
Answered Question
Dec 26th, 2005
Can any one help me on choosing the right IOS for a cisco 3660 router for this module to be recognized by the router.
I think the following IOS would work are these correct?
c3660-ik9o3s-mz.12.4-4.T
c3660-ik9o3s-mz.12.2-15.ZJ
Correct Answer by spremkumar about 11 years 7 months ago
Using the ios file name which you have provided in ur earlier post i did try cross checking the same in ios download page and the data sheet of IDS module. found the exact feature set it belongs to the support to the ids module.
if u need more details or more info i would better suggest to make use of the ios download page and the data sheet of ids module to find the results on ur own..
regds
Overall Rating: 5 (1 ratings)
spremkumar Tue, 12/27/2005 - 02:26
  • Red, 2250 points or more
As per the datasheet ios code with either one of the following feature set is reqd to detect the module.
IOS IP/FW/IDS
IOS IP/FW/IDS PLUS IPSEC 56
IOS IP/FW/IDS PLUS IPSEC 3DES
IOS IP/IPX/AT/DEC/FW/IDS PLUS
IOS ENTERPRISE/FW/IDS PLUS IPSEC 56
IOS ENTERPRISE/FW/IDS PLUS IPSEC 3DES
IOS Advanced Security
IOS Advanced IP Services
IOS Advanced Enterprise Services
As you have mentioned 12.4-4.T Version filename tells that it belongs to this IP/FW/IDS PLUS IPSEC 3DES feature set.
So i would suggest to try uploading this onto ur router and check for the IDS module.
Also do a precheck for the requirements on H/W side like DRAM,FLASH requirement to have this code in ur box..
regds
dehghan Tue, 12/27/2005 - 09:44
Does this mean for this module to work I would need IOS greater then 124-4 but only in the T series and (same for the other IOS) for example 124.6T or any IOS like 12.4-5 series.
Correct Answer
spremkumar Wed, 12/28/2005 - 00:25
regds
