Warning message
problem in debugging acccess server
Dec 27th, 2005
i am unable to connect ISDN users through access servers there is some problem amoung raduis, access server and billing machine so i felt i need to debug first on access server but when i am going to run debug command then i m getting no output, below is the exams. is this right command? i enabled the debugging but i am unable so see the logs (outputs) so what is missing here. please reply me as soon as possible.
AS5300a#debug aaa ?
accounting Accounting
administrative Administrative
attr AAA Attr Manager
authentication Authentication
authorization Authorization
db AAA DB Manager
id AAA Unique Id
ipc AAA IPC
per-user Per-user attributes
pod AAA POD processing
protocol AAA protocol processing
subsys AAA Subsystem
AS5300a#debug aaa acc
AS5300a#debug aaa accounting
AAA Accounting debugging is on
AS5300a#sh deb
AS5300a#sh debugging
General OS:
AS5300a#
johansens Tue, 12/27/2005 - 02:41
  • Silver, 250 points or more
Check that you are logging to your controlling terminal.. do a "show log" and check that it's enabled, like this:
#sh log
Syslog logging: enabled (10 messages dropped, 154 messages rate-limited, 0 flushes, 0 overruns, xml disabled)
Console logging: level debugging, 8175 messages logged, xml disabled
Monitor logging: level debugging, 0 messages logged, xml disabled
Buffer logging: level debugging, 8328 messages logged, xml disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 7800 message lines logged
Here all destinations (except syslog via trap logging) is enabled for level "debugging".
If you are telnet'ing into the box, make sure you run "terminal monitor" to see the messages..
To enable logging of all debug-messages on the telnet session (if it's disabled), do a "logging monitor debugging" in config mode.
Did it help?
