Configure EZVPN Network Extension mode that allows 7940 phone to connect te
tonyam98
I would like to setup my 501 with ezvpn in network extension mode to:
1.Establish vpn tunnel to PIX HUB
2. Establish voip 7940 to call manager
This what I have applied on the pix 501
vpnclient server 6.x.x.x
2.vpnclient mode network-extension-mode
3 . vpnclient nem-st-autoconnect …. Specifies to automatically initiate IPSec
data tunnels when split tunneling is configured. Note that IPSec data tunnels
are automatically initiated and sustained when in network extension mode,
except when split tunneling is configured.
4. vpnclient username (your username) password (password)
5. vpnclient vpngroup HARDWARE password xxxxx
6. vpnclient enable
travis-dennis_2
Level 7
Level 7
I am sure that someone is looking at your config and will post soon but for the rest of us why don't you tell us what the phone is doing and if the tunnel is even coming up or not?
Travis
Itis doing nothing at the moment ...previously when the hub pix 6.3 (4) the phone recieved a 10.60.60.x ip address ... below is this dhcp pool
dhcpd address 192.168.52.2-192.168.52.33 inside
dhcpd dns 206.13.28.12
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd option 150 ip 10.60.60.50
dhcpd enable inside
Is the tunnel up and staying up? If so what happens when you hard code the IP address, TFTP server etc into the phone? Does it work then?
