Warning message
pradeepde Tue, 01/03/2006 - 12:14
  • Bronze, 100 points or more
Routing a call in the IPCC environment involves the following
components/actions:
Routing client, which involves CCM, IP-IVR, PSTN (NIC), and other ACDs
Routing request
Routing script
Device target on the CCM
Route response
Essentially, when a routing client makes a request for a route from the ICM platform, it receives the response and delivers the call to the specified destination. If an IPCC agent is available, ICM software routes the call to the device target
(phone) on the CCM (device targets are dynamically associated with the agent when the agent logs in to the system). If an agent is not available, ICM software can be scripted to route the call to the IP-IVR, where it is queued until an agent
becomes available.
This url should help you:
http://www.cisco.com/application/pdf/en/us/guest/products/ps1844/c1693/ccmigration_09186a00800b4c56.pdf
