Warning message
m.mcconnell Wed, 12/28/2005 - 19:40
  • Bronze, 100 points or more
SNMP will allow you to do this or - at the risk of stating the obvious - you could do a show run and then copy paste into a text editor.
-Mark
baudhayan Wed, 12/28/2005 - 22:12
Create a session for your PIX CLI using Hyperterminal in Windows. In the Hyperterminal window:- Transfer -> Capture Text. Now give the name & location of the text file where you want to store your PIX config.
pix> pager lines 0
pix> sh run
Now in the Hyperterminal window:- Transfer -> Capture Text -> Stop
You should now have your entire PIX config in a text file.
ohnnyj Thu, 12/29/2005 - 11:52
Will this allow me to transfer the file back in to bring these setting back in?
The reason I ask is I am trying to setup a new router to talk with the PIX and need to start from scratch, but if something goes wrong would like to make sure I can get the current config back in a timely manner.
Thanks.
