Warning message
Anand Narayana Thu, 12/29/2005 - 23:45
  • Silver, 250 points or more
i have got cisco 3550/3750 and cisco 6509 with MSCF2 L3 engine II, so it is possible to make as a DHCP server? if so where can iget the related documents? i searced in cisco site, but couldn't get the configuration. Thanks in advance.
Anand Narayana Fri, 12/30/2005 - 00:09
Thanks a lot, will try this option & let you, but does it work across multiple VLAN's? i mean each every VLAN i wanted to hav a different VLAN.
amit-singh Fri, 12/30/2005 - 00:15
  • Blue, 1500 points or more
Yes, It will work for diff Vlans.You have to create different DHCP pools for each Vlan.
HTH,
-amit singh
Anand Narayana Fri, 12/30/2005 - 00:31
Hi Amith,
could you just post me some sample configuration, i am bit confussed. presently i have 3550 for testing purpose, so if it works well, i thought i will implement in 6509. THanks in advance,
