Router 2610 *** Machine Check exception ****
Dec 31st, 2005
System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1999 by cisco Systems, Inc.
TAC:Home:SW:IOS:Specials for info
*** Machine Check Exception ***
PC = 0xfff210c8, Vector = 0x200, SP = 0x680127c8
led of activity green
led of power green
Check
SDRAM OK
FLASH OK
POWER OK
WIC OK
NM OK
What???????
Georg Pauwen Sat, 12/31/2005 - 13:53
Hola,
did this just happen on a previously working router ?
Can you do a 'show version' and post the output, if possible ?
Saludos,
GP
castro-g Sun, 01/01/2006 - 02:52
This it is the unico that leaves when igniting router. it does not arrive at loads the ios. I have bought it but the salesman has disappeared. I have a previous exit of when attached this worked.
C2600 platform with 40960 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x7855e4
Self decompressing the image : #################################################
[OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-IS-M), Version 12.0(7)XK1, EARLY DEPLOYMENT RELEA
SE SOFTWARE (fc1)
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Wed 15-Mar-00 04:42 by phanguye
Image text-base: 0x80008088, data-base: 0x80D4A898
cisco 2610 (MPC860) processor (revision 0x203) with 33792K/7168K bytes of memory
Processor board ID JAD04330L6A (2258657795)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
Basic Rate ISDN software, Version 1.1.
1 Ethernet/IEEE 802.3 interface(s)
1 ISDN Basic Rate interface(s)
1 ATM network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Georg Pauwen Sun, 01/01/2006 - 03:33
this could be a problem with your physical memory. Can you open the box and reseat the memory modules (DRAM & Flash) ? Or better yet, if you have new memory available, replace the memory and load a new IOS ?
Saludos,
GP
castro-g Sun, 01/01/2006 - 03:44
I have replaced the Memory Flash and SDRAM another 2610 Memory of qu works perfectly. and It gives the same problem.
sarbjeet-dhillon Sun, 01/01/2006 - 10:01
hi,
I have run your error through Cisco's Outut interpreter with the following results.
ERROR: The message 'Machine Check Exception' is displayed due to a hardware issue.
TRY THIS: If a new module has been recently installed, first try to remove it to
verify whether it is responsible for the error interrupt. If the error interrupt
persists, try to re-seat all removable components. If no changes like IOS upgrade
or hardware replacement are made and the error message appears continuously replace
the hardware.
Sarb
