Warning message
Richard Burts Mon, 01/02/2006 - 13:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The latest version of the Cisco VPN client can be downloaded from this link:
http://www.cisco.com/cgi-bin/tablebuild.pl/windows
Note that downloading this code requires a CCO login and that there are some restrictions that you must satisfy because of the encryption involved in the software.
Rick
amwoolf11 Mon, 01/02/2006 - 19:21
I also am looking for this and went to the link you provided. Received:
Windows VPN Clients
NOTE:
There are currently no files for this type
at that site after logging in with the same userid I use for this forum.
Is there another location we can get the software? I currently have 4.6 and it doesn't work with my firewall (Zone Alarm 6) but I read that the Cisco 4.7 client does work.
Thanks.
Richard Burts Tue, 01/03/2006 - 06:49
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
When I go to that link it works for me, so I wonder if there is a question about your userid on CCO and downloading software. Try this link and see what results you get:
http://www.cisco.com/kobayashi/sw-center/
This is the main software center downloads page. If you do get to this page, then choose the option for VPN software and you should get to the page that allows you to download the VPN client software.
Rick
amwoolf11 Tue, 01/03/2006 - 15:19
No - doesn't work. My userid is only for the forums (we don't have a support contract on the 3000 box)so I am guessing that is why I can't get to the proper download page. That seems awlful hard on us - I purchased a box and just because I don't get a support contract I can't get software updates???
Anyway, I managed to get things working with the 4.6 client so I am OK for now.
Thanks.
