Cisco IGESM Configuration
Jan 2nd, 2006
Guys,
Can the IBM BladeCenter chassis be used to connect the blade servers to different subnets (different physical segments also)?? The specific config that I have is using the Cisco IGESM switches.
Thanks guys.
Georg Pauwen Tue, 01/03/2006 - 01:48
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
not sure if this is what you are asking, but I think you need an external router for that, that is, you can configure the ports IGESM ports for different VLANs, but in order to route between the VLANs, you need a routing device.
Check the ´Cisco Systems Intelligent Gigabit Ethernet Switch Modules Software Configuration Guide´ in the link below, and consult the chapter ´Configuring Interface Characteristics´ (Figure 7-1):
http://www.cisco.com/application/pdf/en/us/guest/products/ps6294/c1067/ccmigration_09186a00805b60d4.pdf
GP
