Warning message
faulty log!!
Jan 3rd, 2006
Can anybody tell me, when i check the router log, it show a lot of stuff like these
Jan 2 20:02:22 UTC: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 172.26.65.152
Jan 3 00:02:23 UTC: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 172.26.65.152
Jan 3 04:02:24 UTC: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 172.26.65.152
Jan 3 08:02:25 UTC: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 172.26.65.152
Jan 3 08:25:11 UTC: %SNMP-3-AUTHFAIL: Authentication failure for SNMP req from host 172.26.65.236
Thanks.
spremkumar Tue, 01/03/2006 - 03:55
  • Red, 2250 points or more
hi
Do chek the community and the username configured on both the router as well as the snmp servers ,both shuld be the same.
If you have different community string and username configured in the router when compared to the attributes being used by the SNMP server you will get these error logs...
regds
francoisenjeroen Tue, 01/03/2006 - 05:07
Ensure that the community and user name that are used in the SNMP request from the remote host have been configured on the router.
