Warning message
Local LAN Access on VPN Client
mheusinger Tue, 01/03/2006 - 07:28
  • Green, 3000 points or more
as far as I know, you have to configure split tunneling in your VPN concentrator. The client gets the settings from the concentrator and can´t override them.
Hope this helps
Martin
jackko Tue, 01/03/2006 - 15:46
  • Gold, 750 points or more
split tunneling needs to be configured on the concentrator.
1. network list
go configuration | policy management | traffic management | network lists, and click "add".
put the concentrator inside subnet or the list of resources to be accessed by remote vpn client.
2. enable split tunneling
go configuration | user management | groups, and select the remote vpn group.
select "only tunnel networks in the list" for "split tunneling policy"; and then select the network list being created for "split tunneling network list".
