CSV file output from CallManager
Jan 3rd, 2006
I have CCM 4.1 & CER 1.2. Is there a Cisco/3rd party utility, so that I can produce a CSV file of all my phones from the existing CallManager database?
Thanks - Tennisman.
Chris Deren Tue, 01/03/2006 - 12:59
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Well, you can go to Route Plan Report and click View in File in the upper right corner. It includes all phones. It will prompt you to save a file as a CSV.
Hope this is what you are looking for.
Chris
Sascha Monteiro Tue, 01/03/2006 - 13:46
  • Silver, 250 points or more
You can also use BAT and export phones,
this will give more details.
