Warning message
Callmanager QoS for Clustering over the IP WAN
Jan 4th, 2006
Looking for a good QoS policy to apply on WAN links for CM 4.1(3) SR1 Publisher/Subscriber communication. I recall only that bandwidth required is about 982kbs. I'm looking for a specific policy for standard CM services (all but Messaging Interface, Certificate Authority Proxy)
mheusinger Wed, 01/04/2006 - 16:34
  • Green, 3000 points or more
the most simle approach would be to specify source and destination IPs of the two CM f.e. with an access list and use CBWFQ to priotitize the traffic. in case you want to use marking pick a so far unused IP precedence (or DSCP) value (f.e. 2).
Example:
class CMtraffic
match ip address 101
policy-map OUT
class CMtraffic
bandwidth 1000
set ip precedence 2
class class-default
fair-queue
random-detect
interface Serial0
service-policy output OUT
access-list 101 permit ip host host
The traffic between VoIP devices and CM would not be prioritized in this example. For you voip calls and voip signaling you should plan for the nessessary resources as well. But I assume you are aware of it and took care about it.
Hope this helps
Martin
Brian Carscadden Thu, 01/05/2006 - 06:11
It was my 'plan b' to use a simple host ACL, and is likely the route I'll take. Yes, we have an existing ACL/QoS Policy to handle all control and rtp traffic.
Thanks for your input Martin.
jesseramos Mon, 01/23/2006 - 23:16
Will this work over a T1? I have a customer that wants to move their Sub to a remote site connected via T1. I currently have voice traffic prioritized with 768kb as shown here:
class-map match-any VOICE
match ip dscp ef
match ip dscp af31
policy-map VOICE
class VOICE
priority 768
When I tried to add "bandwidth 1000" for the intracluster traffic, I got a message saying I only have 384kb available.
I also tried bringing the priority for voice traffic down to 512, but still not enough for the 928 kb.
What would be the best solution for this scenario?
Jesse
