01-04-2006 11:40 PM - edited 03-03-2019 11:22 AM
I would like to know if there is a way to mirror the IP traffic of the ATM port of a 3640 router to a fast ethernet port of this router.
thanks
HM
01-05-2006 12:01 AM
You should be able to use the 'IP Traffic Export' feature to do this.
Something like the following should work for you:
ip traffic-export profile
interface (outgoing-ethernet-interface-name>
bidirectional ! use this to exports incoming and outgoing IP traffic on the monitored interface
mac-address <48-bit address of the destination host that is receiving the exported traffic>
interface
ip traffic-export apply profile
The host that is receiving the exported traffic should be directly connected to one of the router interfaces.
The following URL has more info on this.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hsec_c/part30/h_rawip.htm
Hope that helps.
Paresh.
PS. Pls rate helpful posts.
01-05-2006 12:24 AM
thanks for this very interesting answer.
But I read the URL and I see that it could impact performance of the router.
I would prefer a solution using port snooping.
At this URL : http://www.cisco.com/univercd/cc/td/doc/product/l3sw/8540/rel_12_0/w5_15/config/8500int.htm#wp1030238
it says that the snooping source port could be at any interface so the ATM interface but it is for the 8540 model. Is ıt the same for a 3640?
thanks
01-05-2006 12:58 AM
The 8540 is a catalyst-based switching/routing platform and has a very different architecture to the 3640 platform.
I don't believe a port snooping feature is available on the router platforms.
As for the performance impact, it only applies on the outbound port where the captured traffic is being sent. There is no other impact on router performance as such.
Hope that helps,
Paresh.
01-05-2006 04:49 AM
ok, thank you very much for your answers
İ will do some tests with IP export
Bye
HM
