Warning message
Store and Forward Switching
Jan 5th, 2006
Quick question, does a Cisco 3750 switch support store and forward switching? If so, is it default? If not, is there a command for it?
I know the 3550's support S&F as default and if the 3750's do then it may resolve my issue.
Wayne
Bobby Thekkekandam Thu, 01/05/2006 - 07:58
  • Cisco Employee,
Hi Wayne,
All of our current switches use the store and forward method.
HTH,
Bobby
wrgoulden Thu, 01/05/2006 - 08:14
Thanks Bobby. In terms of raw switching is there any other differences between the 3550 and 3750?
The reason I ask is I ran a BERT test on two pieces of equipment over a 3750 and it fails the test. Over a 3550 is passes.
Both switches have an IP address for VLAN 1 and portfast and that's it, can't be simpler.
I'm just wondering whether something is on as default on the 3550 but off as default on the 3750????????
Many thanks,
Wayne
