Warning message
CSM-S "Configuration Sync is not supported by this card"
This is the message everytime I try to sync the cards.
NETCSP01#hw-module contentSwitchingModule 5 standby config-sync
NETCSP01#
The are both installed into the same 6513.
Here are the configs
module ContentSwitchingModule 4
ft group 1 vlan 400
priority 30 alt 20
vlan 200 client
description Client Facing CSM Interface
ip address 192.168.100.6 255.255.254.0 alt 192.168.100.7 255.255.254.0
alias 192.168.100.8 255.255.254.0
vlan 100 server
description Server Facing CSM Interface
ip address 172.18.10.6 255.255.254.0 alt 172.18.10.7 255.255.254.0
alias 172.18.10.8 255.255.254.0
module ContentSwitchingModule 5
ft group 1 vlan 400
priority 20 alt 30
I am running the following version
IOS (tm) s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(18)SXE4, RELEASE SOFTWARE (fc2)
What am I missing?
Thank you!!
mchin345 Wed, 01/11/2006 - 09:03
  • Silver, 250 points or more
The configuration synch feature is supported from CSM-S version 2.1.1. I suggest you upgrade your device for using that feature.
