Warning message
srikrama Wed, 01/11/2006 - 03:26
Here with I am attaching .tpl file(unrecov_error.tpl) which is system file .You can get this file in the following path.
c:\Program Files\wfavvid\Prompts\system\default
Srikanth
francis.labelle... Wed, 01/11/2006 - 09:31
Thanks, How can I create my own .tpl file ? Witch tool do I need to use to create a tpl file ?
francis.labelle... Thu, 01/12/2006 - 06:44
When I try to use the .tpl file in a "prompt step". I got this error msg:
"java.lang.IllegalArgumentException: unsupported template prompt"
Does somebody know why ?
Christopher Nagel Sat, 10/07/2006 - 12:13
I understood template prompts to be simply text files, but this is some kind of binary...
Chris
