Strip Digits
Jan 6th, 2006
I have a number of 2851 utilizing the IOS gatekeeper. These all point to a 2851 which is acting as a directory gatekeeper. From the directory gatekeeper down our dialing plan is 10 digits in length. We also are part of a bigger organization in which our directory gatekeeper is neighbored/peered to their gatekeeper. In order for someone from the outside organization to dial into us they have a 6 digit prefix they add to the E164. How can I get our directory gatekeeper to strip the 6 digit prefix from the dial string and forward the remaining 10 digits to the appropriate gatekeeper below it?
Thanks for any suggestions/help!
Alan
a-vazquez Wed, 01/11/2006 - 11:42
  • Silver, 250 points or more
Digit stripping can not be done in Gatekeepers. You have make use of Digit manipluation methods in Gateways only.
itsonlyalan Thu, 01/19/2006 - 10:14
Thanks, so I am using the IPIPGW at the lower levels, would I create a dial-peer that would strip the digits there?
irfan_tariq Wed, 02/22/2006 - 22:56
you can strip digits by using this
voice translation-rule 1
rule 1 /^Number You Want To Strip/ //
then
voice translation-profile voice
translate calling 1
then
translation-profile incoming write this statement in dialpeer .
Irfan Tariq
