Warning message
PIX 520 (6.3.3) H323 Timeout
Jan 7th, 2006
Hello, our PIX 520 seems to be disconnecting H323 clients at the two hour mark. Would someone show me a command on the PIX (6.3.3) to increase the timeout for H323 Clients? (or a better way to stop this?)
Harry
mheusinger Sat, 01/07/2006 - 08:32
  • Green, 3000 points or more
you can change the default settings by using the timeout command:
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 0:00:00
timeout h323 16:00:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
This should solve your problem.
Did it help? Then please rate it.
Martin
