01-09-2006 02:26 AM - edited 03-03-2019 01:21 AM
Hi all,
I am facing a problem with Cisco Catalyst 3550 switch
after booting the switch gives a message
!!! WARNING: The switch is not usable !!!
the post test results are as below
Initializing flashfs...
flashfs[1]: 350 files, 5 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 5008896
flashfs[1]: Bytes available: 10990080
flashfs[1]: flashfs fsck took 8 seconds.
flashfs[1]: Initialization complete.
...done Initializing flashfs.
POST: CPU Buffer Tests : Begin
POST: CPU Buffer Tests : End, Status Passed
POST: CPU Interface Tests : Begin
POST: CPU Interface Tests : End, Status Passed
POST: Switch Core Tests : Begin
POST: Switch Core Tests : End, Status Passed
POST: CPU Interface 2nd Stage Tests : Begin
POST: CPU Interface 2nd Stage Tests : End, Status Passed
POST: CAM Subsystem Tests : Begin
POST: CAM Subsystem Tests : End, Status Passed
POST: Ethernet Controller Tests : Begin
Failed data line test (4).
addr=0x00000,sent=0x10000000 recv=0x800000000
POST: Ethernet Controller Tests : End, Status Passed
INIT: failed satellites initializationcisco WS-C3550-24-PWR (PowerPC) processor (revision L0) with 65526K/8192K bytes of memory.
Processor board ID CAT0923X1TK
Last reset from warm-reset
Running Layer2/3 Switching Image
Ethernet-controller 1 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 2 has 12 Fast Ethernet/IEEE 802.3 interfaces
Ethernet-controller 3 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 has 1 Gigabit Ethernet/IEEE 802.3 interface
Ethernet-controller 4 failed POST
POST error status : external RAM test failed
The password-recovery mechanism is enabled.
384K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:14:6A:7B:86:80
Motherboard assembly number: 73-8100-09
Power supply part number: 341-0029-03
Motherboard serial number: CAT09240JXN
Power supply serial number: DTH09206Z8S
Model revision number: L0
Motherboard revision number: A0
Model number: WS-C3550-24PWR-SMI
System serial number: CAT0923X1TK
The failed post are as follows
Can someone please guide me where the problem is and how it can be solved ???
I am facing the same problem in a total of 12 switches
Thanx in advance
Sreesh
Solved! Go to Solution.
01-09-2006 02:55 AM
usually that means that there is a hardware problem, and that the switch has to be returned and replaced. Below is the explanation from Cisco itself.
Where did you buy those switches ? Are they new, and do you still have a warranty ?
A POST failure usually means that there is physical damage to the interface. If an Ethernet Controller which controls four interfaces fails, it results in the failure of those ports. A common cause of
such damage is ESD.
Failure of any of these diagnostic tests is normally fatal and usually requires a Return Material Authorization (RMA) to resolve the problem.
To be sure of this, reset the switch with a console connection established and capture the actual bootup diagnostic information, then create a service request with Cisco Technical Support.
GP
01-09-2006 02:55 AM
such damage is ESD.
GP
01-09-2006 04:43 AM
Dear GP,
The switches comes froma lot of about 154nos. of 3550 switches procured from cisco thru HCL Inc. They are brand new and still comes under the warranty period from Cisco.
Thanx for the advise, i think i should seriously take up the issue now with th management
Sreesh
