Warning message
PIX config
Answered Question
Jan 9th, 2006
Hi;
I'm new to the PIX firewall and I'm looking to see if a project is possible. I have 1 PIX and 3 ISP's that need to be connected for both redundancy and network protection. I need to know if my configuration is possible and if so some info as to wher ei can find some direction to resolving my project. The PIX has a restricted license but that can be changed if needs be. Any info in this matter would be greatly appreciated
Correct Answer by sachinraja about 11 years 7 months ago
cool. you can use BGP and a new feature called Optimised Edge Routing... OER can be used to intelligently poll the latency, hop counts, link load etc and automatically divert traffic to the best possible link... Search for OER on the CCO and you can find materials about that...
Hope this helps.. mark the post as solved, which can help others. rate replies if found useful.
Raj
Overall Rating: 5 (1 ratings)
sachinraja Tue, 01/10/2006 - 02:52
  • Red, 2250 points or more
Hello
Are the routers connecting to the PIX outside or to different DMZ interfaces? Basically PIX can have only one default route in it. It cannot handle load sharing or failback between ISP's. You have to do all the backup routing on the routers.
HOpe this helps. all the best...
Raj
pacsniffing Tue, 01/10/2006 - 05:57
the initial plan would hav been to use a layer 2 switch b/t the ISP and the PIX, was trying to avoid BGP but thanks for the info
Correct Answer
sachinraja Tue, 01/10/2006 - 07:53
Raj
