Warning message
Multilink PPP on FR and ATM
Jan 10th, 2006
Hi ,
I am having this scenario:
Main site: Router 3745 (ATM)
Remote site: Router 1721 (FR)
I want to have a PVC of 256 between the 2 points.
On the remote site, hey cannot install a 256 access-point and pvc so they are going to install 2 x 128 PVCs.
I lknow i have to use mutlilink PPP and i have a sample configuration for it so i shouold be ok with that on the FR for the remote site.
However, i thought they would give me a 256kbps for my ATM site, and the ISP would take care of the multilink situation on their ATM-FR switch.
What is the correct scenario for this ??
Do i have to do multilink ppp on both routers main and remote, or
2. 2x128 kbps only on remote, and have a 'normal' 256 kpbs on main router and the ISP should take care of it????
Also, if i need to use multilink on ATM can someone give me a sample configuration example ???
George
Overall Rating: 3.5 (2 ratings)
mheusinger Tue, 01/10/2006 - 01:27
  • Green, 3000 points or more
first I would assume that you also get two PVCs on the ATM interface. as far as I know there is no way of "merging" two FR-ATM PVCs into one. So the ISP can not solve your problem there.
When you have two PVCs on each end it is your own "pleasure" to get multilink PPP up and running.
Sidenote: you could also setup load balancing through dynamic or static IP routing in this case.
For the ATM PVC it would be advisable to read
"Using Multilink PPP over ATM Links"
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a00804a4095.html
You wrote that you are aware on how to set up MLPPP on the FR side. In case you need help there as well just ask for it.
Hope this helps
Martin
Hope this helps
dukenukem Thu, 01/12/2006 - 01:54
Hi and thank you for your reply.
I am more interested now in the load balancing.
I have read that the router will automatically load balance if one or more paths are known to the same destination.
In my case, i have a central router 3745 and 6 remote disctrict offices, all which are stub networks.
So i only use static routing.
In one new district i want a 256 kbps PVC but the ISP can only provide 128. So he can give me 2 FR 128 kbps PVCs on the remote site and two ATM 128 PVCs on the 3745 router.
So if i used load balancing, it should be straight forward...
Can you please comment on my thoughts for my configuration.
I will have the correct FR and ATM configuration for each router.
IP ADDRESSING
cisco 1841 (remote) FR:
LAN IP : 10.51.122.X SM : 255.255.255.0
PVC 1 128 kbps IP: 10.51.10.30 SM: 255.255.255.252
PVC 2 128 kbps IP: 10.51.10.34 SM: 255.255.255.252
cisco 3745 (Central) ATM:
LAN IP: 10.51.22.X SM: 255.255.255.0
PVC 1 128 kbps IP: 10.51.10.29 SM: 255.255.255.252
PVC 2 128 kbps IP: 10.51.10.33 SM: 255.255.255.252
would these static routes work for load balancing:
Cisco 1841 (Remote)
static routing table:
ip route 10.51.22.0 255.255.255.0 10.51.10.29
ip route 10.51.22.0 255.255.255.0 10.51.10.33
Cisco 3745 (Central)
ip route 10.51.122.0 255.255.255.0 10.51.10.30
ip route 10.51.122.0 255.255.255.0 10.51.10.34
Would these entries just be enough for load balancing to work ???
I have also posted a thread for a comparison between load balancing and Multilink PPP and why should i chose each one ????
Can you shed some more light on this please ??
George Serghiou
pkhatri Thu, 01/12/2006 - 02:01
  • Purple, 4500 points or more
Hi George,
Your config is fine. Your static routes will load balance over the 2 links as per your requirements. Just be sure that your provider supports FR-ATM OAM interworking so that your FR/ATM PVCs are brought down if there is a problem with the PVCs. Otherwise, you might end up black-holing half your traffic.
However, you will have the limitations that I have outlined in my response to your last post.
Paresh.
arvenugopal Tue, 01/10/2006 - 01:30
Hi George,
I hope you are looking for the Multilink over ATM please find the sample config for the requirement.
Note: This section shows the parts of a core Cisco 3660 router
!--- configuration that is relevant to MLPoATM.
class-map match-all Voice_Stream
match access-group 100
class-map match-all Voice_Control
match access-group 101
policy-map toortr01
class Voice_Stream
priority 175
class Voice_Control
bandwidth 18
random-detect
interface loopback0
ip address 10.16.0.105 255.255.255.252
interface ATM2/0
description To Carrier E3 ATM Service
no ip address
interface ATM2/0.15 point-to-point
pvc toortr01 0/58
vbr-nrt 406 406
tx-ring-limit 8
protocol ppp Virtual-Template15
interface Virtual-Template15
bandwidth 320
ip unnumbered loopback0
ip tcp header-compression iphc-format
service-policy output toortr01
ppp multilink
ppp multilink fragment-delay 14
ppp multilink interleave
ip rtp header-compression iphc-format
!--- Note: Do not configure
!--- IP addresses directly on any configuration source,
!--- such as a virtual template, whenever the possibility
!--- exists that this information is cloned to multiple
!--- active interfaces. The exception to this rule is the
!--- rare case where the intent is to define multiple parallel
!--- IP routes and have IP do load balancing between them.
!--- If an IP address is present on the configuration source,
!--- this IP address is copied to all the cloned interfaces.
!--- IP installs a route to each of these interfaces.
Branch Frame Relay Router
!--- Note: This section shows the parts of a branch Cisco 2600 router
!--- configurations that is relevant to MLPoFR.
policy-map dhartr21
class Voice_Stream
priority 240
class Voice_Control
bandwidth 18
random-detect
interface loopback0
ip address 10.16.0.106 255.255.255.252
interface Serial0/0
description To Carrier Frame Relay Service
encapsulation frame-relay IETF
frame-relay traffic-shaping
interface Serial0/0.1 point-to-point
frame-relay interface-dlci 38 ppp Virtual-Template1
class dhartr21
bandwidth 320
max-reserved-bandwidth 85
service-policy output dhartr21
ppp multilink
ppp multilink fragment-delay 10
map-class frame-relay dhartr21
frame-relay adaptive-shaping becn
frame-relay cir 320000
frame-relay bc 3200
frame-relay mincir 320000
ps: rate it if you find the docs useful.
