Warning message
NO-NAT / Cisco 837 ADSL Router
Jan 10th, 2006
I am currently try to configure a 837 with a block of 16 public ip address i do not need private ip's dhcp dns or anything else from the router just for the usable ip to be routed back and fourth can any one point me in the right direct for some config's
Many Thanks
Aaron Bolton
pkhatri Tue, 01/10/2006 - 16:34
  • Purple, 4500 points or more
Hi Aaron,
Since you are saying NO-NAT, I presume you do not want to use NAT. I also presume that this block of public IPs is to be used on your LAN segment behind the router.
Essentially, all you need to do is:
1. configure the LAN interface on your router with an IP address in this public range.
2. Assign IP addresses from this range to your PCs on this LAN segment
3, Configure a default route on your 837 that points to the WAN interface
4. Instruct your ISP to route this public range to your WAN link.
Hope that helps,
Paresh.
abolton291078 Tue, 01/10/2006 - 21:47
Hi there,
thanks for the quick reply, what im trying to do is pretty much what you have described although i need the router interfaces ATM0 and ETH0 to have the same ip so i am not wasting 2 ip's on the router and the ISP is already doing the routing, basicly the connection is already there i have upgraded the router from an old effecient network 5861 to the Cisco 837 and im looking for some example config which i can modify to fit my exsisting network
pkhatri Tue, 01/10/2006 - 21:57
Hi Aaron,
You cannot assign the same IP address to more than one interface.
Since you stated that you have 16 public IPs, I presume you have a /28 block, giving you 14 useable addresses. One possibility is to divide the block into two /29 blocks, giving you 6 useable addresses per block. You would then use one block on your ATM interface and the other on your Ethernet interface. However, I have a feeling that you are not going to like that.
An alternative is to setup your 837 to be a bridge. In that case, you would not have to assign any IPs to the 837 at all. However, in that case you would have to get your ISP to use RBE (routed bridge encapsulation) to terminate the ATM link. That would give you a lot more addresses to use on your LAN segment. I have a config that does precisely this if you choose to go down this path...
Hope that helps.. pls rate helpful posts.
Paresh.
pkhatri Tue, 01/10/2006 - 22:05
Hi again,
Usually the ISP would assign you a /30 or /31 subnet for your WAN link.. are you sure your ISP has not done that ?
Paresh
arvenugopal Tue, 01/10/2006 - 22:37
to summarise the things,
1) you can use the block of 16 IPS with with CRB. the url is given below
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_guide_chapter09186a0080118d24.html#19696
2) if your ISP Gives gives you the /30 or 31 it makes the life simple and easier.all that you have to do is use the 16 block ip in ur lan
hope it helps
abolton291078 Wed, 01/11/2006 - 01:14
Hello again,
I do have a block of 16 /28 public ip's and as mentioned only 14 are usable the config i am looking for is below, I have done this on 2 other routers generally with out a problem even on this same connection. unfortunatly i cannot get the isp to make any changes to how they provided these to me
81.xxx.xxx.96 - Networks Address (un-usable)
81.xxx.xxx.97 - Router - Hopefully Cisco 837 :)
81.xxx.xxx.98 - Server, workstation or other device
81.xxx.xxx.99 - Server, workstation or other device
81.xxx.xxx.100 - Server, workstation or other device
81.xxx.xxx.101 - Server, workstation or other device
81.xxx.xxx.102 - Server, workstation or other device
81.xxx.xxx.103 - Server, workstation or other device
81.xxx.xxx.104 - Server, workstation or other device
81.xxx.xxx.105 - Server, workstation or other device
81.xxx.xxx.106 - Server, workstation or other device
81.xxx.xxx.107 - Server, workstation or other device
81.xxx.xxx.108 - Server, workstation or other device
81.xxx.xxx.109 - Server, workstation or other device
81.xxx.xxx.110 - Server, workstation or other device
81.xxx.xxx.111 - Broadcast Address (un-usable)
I hope this explains my scenario a little better
abolton291078 Wed, 01/11/2006 - 01:44
I have fond this configure after a bit of googling should this fit my needs
Your ADSL login: [email protected]
Your ADSL Password: lxxxxxxx
Virtual Path Identifier: 0
Virtual Channel Identifier: 38
Data Link Encapsulation: PPPoA (PPP over ATM)
PPP Properties: VC Multiplexed or VC Based or VCMUX
Below are details of the static IP addresses allocated to you:
Network: x.x.40.32
Gateway*: x.x.40.33
Netmask: 255.255.255.240
* The gateway address will be automatically assigned to your router when
you connect via DHCP.
This is the configuration I have created :-
hostname voiprouter
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
no aaa new-model
ip subnet-zero
ip routing
ip ips po max-events 100
no ftp-server write-enable
interface Ethernet0
ip address x.x.40.34 255.255.255.240
no ip route-cache
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no ip route-cache
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Dialer0
description $FW_OUTSIDE$
ip address dhcp
ip mtu 1452
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname USERNAME
ppp chap password 0 PASSWORD
ppp pap sent-username USERNAME password PASSWORD
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
control-plane
scheduler max-task-time 5000
end
beckerola Wed, 01/11/2006 - 01:21
And wouldn't it be more simple just doing an "ip unnumbered ethernet0" on the ATM interface?
This will save one IP address on the router, although you will have to use another one in the same range on the other side. In any case you are saving one IP.
Maybe I lost something but I think this should work.
Hope it helps.
abolton291078 Wed, 01/11/2006 - 01:25
this is very close to what i am looking for do you know any example configs as i am very new to cisco and need a base to start from.
beckerola Wed, 01/11/2006 - 02:00
This link may help. The first example refers to serial ports but they are valid for ATM interfaces as well. Teh seconf one uses ATM and as you can see, if you want to use ATM sub-interfaces, ip unnumbered works for it too.
Hope it helps.
http://www.cisco.com/warp/public/701/20.html
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080094344.shtml
abolton291078 Wed, 01/11/2006 - 03:38
this looks like the solution
1. assign the WAN ip to the eth0
2. then use ip unumbered for the atm0
3. create the dialer profiles
