Warning message
Adding IP to Catalyst 3535
Jan 12th, 2006
I have tried adding an IP to my Catalyst 3535 by add this:
interface Vlan1
ip address 192.168.5.5 255.255.255.0
then
no shut down
But I can't ping it, do I have to have a network cable into a specific port
stomasko Thu, 01/12/2006 - 06:10
  • Silver, 250 points or more
Do a show ip int brie and make sure VLAN shows up.
Make sure your pc has a network address in the same range as the switch.
Port should not matter unless you changed the vlan of the ports, if that's the case make sure you plug into one that is in VLAN1.
Steve
carl_townshend Thu, 01/12/2006 - 06:31
Hi there
The only things i think it may be are
check what vlan your plugged into, put an ip default gateway on the switch if your on a different lan, nake sure your pc is on the same subnet !!
thanks
Carl
