SW Upgrading NAMS Via Ciscoworks
When upgrading NAMS via ciscoworks, does ciscoworks telnet via the chassis or directly to the module.
The problem i have is that you dont seem to be able to telnet directly to the NAM. But you can connect via sess slot command
Ciscoworks is configured with the local username and passwood that allows access via the sess command but shows it as incorrect. Can't work this out.
Any help would be appreciated
rmushtaq Fri, 01/13/2006 - 16:35
  • Blue, 1500 points or more
Unfortunately, ACS cannot be used for the NAM CLI login, only for the web accounts.
