01-12-2006 08:04 PM - edited 02-21-2020 12:38 AM
hi
i have a question,i have a pix 501.Now on the inside interface can we have both public ip+private ip's.
internet<-->router<-->pix 501<-->(public ip+private ip)
Pleas tell me how it can be done if possible.
01-12-2006 11:39 PM
hi
Its not possible to have both Public/private behind the Inside interface as the PIX doesnt support the secondary addressing concept.
If you have another port (which is not the case with 501) u can assign the public ip to that other free port.
regds
01-13-2006 03:38 AM
Option 1:
You will need a layer 3 device(could be a switch) before the pix to achieve this. However this will introduce an additional hop.
Option 2 (recommended): use private ips internally and for the host requiring public ips use static NAT on the pix.
01-14-2006 08:02 AM
just wondering what the ultimate goal here. perhaps we can provide a workaround.
